76 CB750 Noise
yes. There are only two rotors...early and late and they are interchangable. The early ones just weigh more.
No need to replace if the teeth look ok. nothing ever goes bad on them.
As long as the valve in the oil pump is holding and the oil is still in the tank then there shouldn't be that much oil in the motor itself. Put it on a center stand or prop it upright then what oil is in the bottom wont drain to the left side.
Welp, I replace the stator rotor and the big gear and the good news is that there is no more loud clicking noise. The bad news: it's still not running. Now it sounds like any other bike that won't start. It goes through all the theatrics but it won't run. I have some starter fluid but don't quite know where to spray it if at all. I've tried kick starting it as well. I'm scared to flood the m
