Castle Bravo
Hello all,
I'm new to the forum but am presently collecting parts for my 1979 and will soon begin (and thoroughly catalogue for everyone) a hybrid genre, mostly cafe' build. I live in a brutal, merciless and scorching desert called Phoenix Arizona. Its already a given that 5-6 months a year, the bike will sit and cannot be taken into 110-118 degree weather. I recently read an ad for a company that sells carb alteration kits designed in part to help with heat issues. They are larger jets and the idea, as they espouse, is that running rich keeps a motor cool. They also say, specifically their kit improves the cooling of a motor that has low-pressure after market exhaust...which of course makes a motor run more lean. So it all comes down to, is that real? Will it run somewhat more cool rich? If I can drive in 100 degree weather rather than 98, I'd get 15-20 days a year back. Also, would header wrap prevent heat from drafting back onto the engine block or would the header wrap simply trap more heat against the exhaust ports, making the heat worse? If you have any other suggestions in regards to heat, please illuminate me. I want to use an oil cooler and will when I can but cannot presently invest in one. Thank you for your wisdom,
