Cycle x and dynoman have them. But you do know you are supposed to have the correct surface finish and the surfaces have to be absolutely flat to use MLS.
Head and top of cylinder both need to be flat and have the correct finish...not just a normal surface finish, make sure you specify for mls but .doing only the head is putting a bandaid on half of a cut. MLS gaskets do not compress and dont conform to imperfections which is the reason they have to be flat and have a fine surface finish
