The Jimbonaut
The Jimbonaut
I'm trying to check the valve clearances on my '81 cb750, and there's a lot of oil in the pockets in the cylinder head surrounding the valve lifters - so much oil in fact that the shims are totally covered in the stuff. The front cam (exhaust cam?) is almost overflowing over the valve cover gasket.
Is this normal? Can I go ahead and check the valve clearances or do I need to drain some of this oil? In which case, how?
Thanks!
-J
Thanks!
-J
