Lwr Case - Is this a crack?
Azdevil09
36
Phoenix
Just inspecting and saw this. Not sure if this is a crack. Nothing is visible from the inside of the case. So not sure what’s going on here if if it is any concern.
Looks like mark from the casting process, very common.
I'd say the same thing. The process by which these engine cases were cast leaves a lot of "cobweb"-like strings of extra metal inside the cases. When I dropped the oil pan on my own 1980 CB750K I saw the same thing.
If you want to be extra sure, look at it under some magnification and poke it with a pick. It should just be a ridge of extra material above the surface.
I would probably agree that it is casing marks. If you want to be absolutely sure then you can use a penetrating dye (like iodine) and see if it bleeds through the casing. Similar to a magna flux to test welds, but much cheaper. You can use most any small molecular liquid (like white gas with a colour added), these have a tendency to bleed through a crack in metal.
