The Fabricator
This is my first post but not my first forum so I'm hoping you guys can help me, I'm completely confused . I have a 71 CB750 that I bought last fall and the guy who had it before me had it for 4 years but he never tried to start it. I'm trying to get it started so I can work on it through winter so its ready for next summer. I'll tell you everything I've done:
- new batter fully charged
-Gapped the spark plugs to .026"
-gapped the intake valves to .002" and the exhaust to .003"
-gapped the points to .012"
-tune up kit from Charlie's Place that had new points and condensers
-rebuilt the carburetors, set the floats to 26mm and turned the air adjust screw out one turn from bottoming out
-new spark plug caps and the correctly oriented to the right cylinders with clean spark plugs
-I didn't check the compression but the bike has 26,xxx miles on it, is very clean and when I kick it over it feels like it has good compression
-The yellow wire is going to the coil for cylinders 2-3 and the points, the blue wire is going to the 1-4 coil and points
I have good spark, I have fuel and air so the recipe for it to run is there but its spitting out the carbs. I did a static timing adjustment using a test light and I have it so the the points open on the "F" mark for both 1-4 and 2-3 so the time should be good enough to get it running so I can fine tune to full advance with a timing light. A local dealer said maybe I switched the cam around on the spark advance when I took it apart to cleaned it. I rotated the the cam 180 degrees but then the points for 1-4 were closing on their respective "F" mark and 2-3 points were closing on their respective "F" mark. That's not right so I turned the cam back around and was able to time the points correctly to how the four manuals I have say they should be. When I go to start it its spitting out the carbs and I might get a pop out of one of the exhausts. I've been banging my head against the wall with this and I have no idea where to go from here. As far as I know everything has been done correctly but something seems like its 180 degrees off from where it should be? Did someone put the cam in backwards?!? That's a joke since I don't believe its possible and I see no signs that the engine has ever been taken apart in anyway. Any help would be greatly appreciated and I'm completely open minded to ideas; thanks
