For Sale - Honda CB750 All Billet Triple Clamp Assembly
Redline
Halton Hills, Ontario, Canada
Ripple Rock Racer Honda CB750 All Billet Triple Clamp Assembly brought to you by Bullit Custom Cycles has a machine carved top triple to match the bottom triple design to create a custom "stepped" look to fit your '69-'78 CB750. The bottom triple is double bolted on each side and is increased in thickness for strength (1 1/2 inch billet).
The bottom triple also has the "spacer" machined into the piece, there is no need for an additional spacer washer to fit the tapered roller bearing. The top triple is machined to mimic this "spacer" look design. The bottom triple comes complete with the tapered roller bearing pressed on (1 thousand of an inch interference fit) and a bottom dust seal. The new steel steering stem is riffle drilled to decrease weight and is designed with a bottom lip to fit securely into the machined relief in the bottom triple clamp. This special design feature guarantees a precise fit that will not accidentally come apart!
The bottom triple has the steering stops fitted and the top triple is drilled to accept the stock instrument cluster using our instrument gauge brackets or will accept our billet ignition bracket and also our Dual Mini Gauge Console or our Mini Gauge Instrument Kits available from Bullit Custom Cycles !
All Billet Triple Clamp Assemblies come with an upper and lower Tapered Roller Bearing Kit which insures a straight bolt on installation into your Honda frame!!
Your cost on this beast is $599 and comes with the tapered bearings installed!!
