GofastGardner
So I have been restoring a 1980 CB750f and finally was making headway. I got it running and got the carbs relatively balanced. The other day I went to start her up and heard a loud bang and the engine appeared to seize. It would not turn over for a few tries. Then all of a sudden it worked fine and started right up. Then I noticed that oil was pooling on the ground. There is a pretty sizeable hole in the lower right side of the crankcase and the pieces that broke out have a noticeable point of impact from the inside. However, nothing appears to be loose and the engine still runs fine. What could have caused this? Its like something was loose in there and got in between the crank and the crankcase wall. Can I JB weld it back together and hope for the best? Is my project over? Thoughts and guidance would be awesome.
Ryan
Ryan
