PensylDJ
I have the code for the crankshaft main and connecting rod bearings. And I think the case codes. Does anyone know where I can get the correct bearings? I know from hard experience that you have to match the codes. particularly on the older engines. I had the crank measured and evaluated and it is in range. So should be no problem there.
Also looking for new steel Ferrules for the oil lines. Looked all over and can't find any.
