Help troubleshooting an engine that won’t start
Mcnaldo
Portland Maine
Inexperienced mechanic here. I’m learning through the internet and really enjoying it. My 82 CB750c currently won’t start. The initial problem arose when riding to my friends house. Suddenly I could not go over 35 and the engine would stall out when I engaged the clutch and restart when I disengaged it. I made it to his house and that’s where it stays until I can fix it. When initially troubleshooting I found the charging system was giving me less than 13volts when reving. Going through it I have done the following things.
Replaced the rotor, it tested weak
Tested the stator OK
Replaced the brushings
Replaced the ignition coils, I think they were ok but the wires were old and cracking so I swapped it out
Tested the rectifier OK
As I have been working on the bike it has become harder and harder to get it started. At first it would start but I would have to throttle it to keep it running. Currently I can’t get it to start at all. The only thing I get now is the occasional singular pop similar to a backfire.
I get a visual spark out of each plug when I test them.
My charging system was definitely weak but maybe that wasn’t fully the problem.
I’m feeling a bit directionless at the moment. Can any of you nice people steer me in the right direction?
Thanks in advance.
Check compression. Probably low with tight valve clearances.
