exhaust wrap
Titanium dei is the best I've used. It doesn't discolor or get brittle with age/use. As with any exhaust wrap, it will hold in moisture, so if your going over bare metal, some sort of high temp paint should be used first.
At first when I read 260 I thought too low, then I realized you mean Celsius. I believe that should be fine.
I used DEI wrap on the crossover on my supercharged Pontiac and it worked great. The crossover was near the supercharger and the wrap lowered the intake air temp. a bit. If I remember it was a kit that came with a high temp clear coat that I sprayed on the wrap. Never had any issues.
