So the first cleaning wasn't as thorough as the first. I found on the second attempt that I could remove the slow jets and they were clogged! It ran after that but not liking the throttle. The third cleaning was a full teardown. Took bodies off the rack and everything, I was hoping it was the airbox, but now I'm not sure. Accel pump cleaned as well. I have yet to try running it after this third cleaning.
Ill have a look for this PDF on carb synching. it has to be done, I haven't started it yet.
As for the mixture screws, I set them all to 1.5 turns out as a "starting" point - pun intended.
Also I noticed the needle clips were in the leanest position so I put them to the center position to richen it up a bit.
I cant synch the carbs until I get it running consistently
Could you direct me to this PDF on carb synching? I don't see a place where the moderators have put a sticky for common requests.
cheers!
cheers!
