170 psi is the new engine spec, runs fine but a little slower in increments down to 130.
Accel pump will only be as you increase the throttle, once you have screwed it open and bike still not pulling hard then not pump, as it only works when the throttle IS MOVED. And if the mixture has been richened no need for it at all, it only comes on US spec bikes, the Euro ones do not even have it. Past about 2 full turns on idle mixture you really don't need it if rest of carb working right. It only has effect at low throttle openings.
You can yank the airbox rubbers and using a small mirror look at the carb inlets for the squirt of fuel each has as you open the throttle up. The squirter is that little brass stub you see sticking up on the right that the choke plate has a notch cut in the bottom for. The squirter shoots a small shot of fuel at the needle location when worked.
