Good day gentlemen and gentlewomen, hope now the weather is better you are getting some rubber on the asphalt.
I was wondering if any of you know if the electronic ignition from a DOHC will fit the SOHC?
The plate the pickup coils are mounted to looks the same size as the plate our points are on,
but I was wondering about the advance mechanism and cam that the trigger is mounted to.
I see these used electronic ignitions MUCH cheaper than the new ones and thought maybe I
could get away with a retrofit that only tickles my wallet.
Thanks.
Thanks.
