For Sale - 1979 cb750f part out W/ GSXR front end
lith929
Huntley, IL
I am parting out a custom build cb750f that I was working on over the past couple years. The frame was heavily modified for a monoshock 2004 gsxr600 rear end and it has a clear Illinois title It has a 2004 Gsxr600 front end as well. Bike last ran 1 year ago when teardown/build started, but trans falls out of 4th under very hard acceleration. I do not have time to finish and need it gone to make some room in garage. Located in Huntley, IL 60142. I can get more detailed pics if need be and prices are negotiable within reason. email : eschwantje@hotmail.com
1. 2004 GSXR600 front end: 400$ obo (includes custom machined stem for cb750 fitup, both triple trees, forks, gsxr wheel and brand new tire, rotors, calipers, ss dual brake lines, brand new custom length throttle and clutch cables, 19MM master cylinder, crg adjustable shorty billet levers, triangle headlight and mount) This front end is ready to bolt up and go.
2. 1979 CB750F engine. 200$ (falls out of 4th gear under hard acceleration)
3. 1979 CB750f complete carbs 150$(single pod filters included)
4. 2004 GSXR600 rear end: 150$ (includes swingarm, wheel with modified cush drive to run chain closer to tire with no tire rub, master cylinder, caliper, lines, 520 chain, sprocket and spacer, and bushing for cb750 swingarm pivot)
5. Heavily modified frame with clear Illinois title: 150$
6. Modified gas tank to have ignition switch and choke lever on top of gas tank: 75$
7. Stock speedo, tach, and odo dash: 75$
8. Set of stock wheels: 100$ (front wheel has dual rotor mounts)
9. Stock Honda gas tank badges
engine
will you part out the engine? I am in need of the camshaft holders, exhaust flanges, stator and stator cover. or whole engine for $150.
