Mr_FlightNurse
Hey Everyone!
I am writing because I have just received my engine build from the wonderful Ken at Cycle Ex.
I’m very amateur, and I don’t know what some of this stuff is quite frankly. Please educate me or let me know what you think of the build!
The build is as follows - copied from Ken’s invoice
Build a 970cc Hot-rod motor using pump gas and parts listed.
SUPER GASKET KIT
STROKER PISTONS
CARILLO RODS
DRI FILM GREEN ROD BEARINGS
DRI FILM GREEN MAIN BEARINGS
STOCK WEIGHT DELUXE CRANKSHAFT.
EBC CLUTCH FRICTION PLATES
CHAIN WHEEL
PRIMARY CHAIN
CRYO CAM CHAIN
PRIMARY CHAIN TENSIONER. 8% SPRING
CYCLEX RACING CAM CHAIN TENSIONER
ADJ CAM SPROCKET & BOLTS
SUPER FINISHED. CLOSE RATIO RACE TRANSMISSION.
HIGH LIFT VALVE GUIDES
F2 VALVES
F2. F3 TOP RETAINERS AND SPRING COMBO
TITANIUM NUTS
34MM CARBS
INSULATORS & CLAMPS FOR RS34
DYNA S IGNITION
NEW FIELD COIL RE-WOUND
CX-11 CAMSHAFT
OIL FILTER ADAPTER KIT
MAGNETIC DRAIN PLUG
OIL PRESSURE GAUGE
ALLEN COVER SCREW KIT
SPARK PLUGS
DOWEL PIN KIT
AIR FILTER MIKUNIS
TRANNY BEARING KIT
31 ARP BOLTS
HIGH OUT-PUT STARTER
BLACK POWDER COATED ENGINE
Breather Uni-filter
Ignition cover, gasket and screws.
Tach plug.
MACHINING:
DESCRIPTION
# 3 PORTED
COMBUSTION BLENDING
F2 DRAIN HOLE MOD
BIG BORE RE-SLEEVE
BORE TOP ENGINE CASE
LINE LAP CASES
Feed “O” ring modification.
The engine is complete, but I am building the rest of the bike with my father-in-law. So we are in the process. I just wanted anyone’s opinion on the engine build. Ken at Cycle Ex does incredible work!
Thanks for your time!
Very Respectfully,
- I.T. Krüg
SUPER GASKET KIT
STROKER PISTONS
CARILLO RODS
CHAIN WHEEL
PRIMARY CHAIN
CRYO CAM CHAIN
F2 VALVES
TITANIUM NUTS
34MM CARBS
DYNA S IGNITION
CX-11 CAMSHAFT
MAGNETIC DRAIN PLUG
OIL PRESSURE GAUGE
SPARK PLUGS
DOWEL PIN KIT
AIR FILTER MIKUNIS
TRANNY BEARING KIT
31 ARP BOLTS
Breather Uni-filter
Tach plug.
MACHINING:
DESCRIPTION
# 3 PORTED
COMBUSTION BLENDING
F2 DRAIN HOLE MOD
BIG BORE RE-SLEEVE
LINE LAP CASES
Very Respectfully,
- I.T. Krüg
