oil leak coming from where tachometer cable enters piston cover
It's been a while since I've had it out but I think there's one or two O-rings in there. They might just need replacing.
There is a trick to getting the seal out. You drive a small diameter screw through the seal. As you keep screwing it in the tip will bottom on the seal land and the threads will back out the seal.
