Stoney
Hi everyone, I've pretty much run out of ideas with this!
I'm riding a 78' sohc cb750k7, and since I first got it the brakes have rubbed when turning left.
It's not enough to notice when riding (sometimes a little squeal), but it's impossible to wheel around when turning left.
In an total overhaul of the brake system I have replaced:
The entire master cylinder
Brake caliper piston
Piston seal
Pads
It's running braided hoses which I have already checked for trapping/pinching.
I have also bled the system out a few times and fiddled with the caliper arm to get the right clearance.
Removing the small nylon ring that usually sits behind the brake pad has helped slightly, but the squealing obviously got worse.
I'm starting to suspect bad wheel alignment or the caliper arm being faulty, but thought I'd just get everyone's 2 cents before I get stuck into it this weekend as the forum has been an amazing help so far.
Thanks in advance!
Piston seal
Pads
Thanks in advance!
