Results 1 to 5 of 5
  1. #1
    CB750 New Member DCMojoJim's Avatar
    Join Date
    Mar 2020
    Washington DC
    Posts
    Angry 95 CB750 shorter slow jet work Y/N ?
    Have an Winter project bike , No history on it and been sitting outside for a few years.
    Everything on the Bike was well gummed up , rebuilt hydraulics on brakes , battery voltage regulator,cleaned tank etc.etc.
    Bought a carb rebuild kit on ebay (chinese). I know cheap crap, but bikes rough and not sure if worth dropping $ into it .
    1st thing is the slow jet received is the shorter Keihnin 35jet 23.5 mm long and a 35jet 28mm long came with bike.
    Will it draw fuel ? even though it is higher in float bowl ?
    The main jets themselves are taller on rebuild kit and the cross holes in the piece it attaches to are a smaller diameter .
    The needle ? Forget about it ! It won't even fit , Can't install , it has a extra thick piece at the top and won't sit and can't lock into place.
    Boiling old parts might be my only option at this point
  2. #2
    CB750 Guru amc49's Avatar
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    3,428
    Sounds like completely wrong parts set. Pilot will NOT work.
  3. #3
    Join Date
    Mar 2020
    Washington DC
    Posts
    Yep , PITA for sure , Waited a month for janky ebay chinese rebuild kit ,
    I can use float bowl gaskets and pilots screws (at least they work)
    No knowing history of bike is added frustration .
    Boiled all "original" stuff and and was able to clear the slow jet.
    The original jets were <105 and 112 is stock ? New jets are 112 but a little bit longer and going to try using them.
    Even had parts older dynojet kit parts and trying to make heads or tails of it all. (3 different sets of needles )
    One Question does the jet needle actually seat closed at rest or hover a little ?
  4. #4
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    3,428
    It hovers and must wobble a bit, it allows the flow to center it. Positive solid contact would lead to lightning wear.
    Need Keihin brand jets, after market often do not flow right and will not be so closely matched in flow. Even Dynojet won't match OEM flows, they commonly flow less with bigger numbers to make people think they were jetting 'up' when they weren't.
    https://moto-odejda.ru/file/HondaNithawk.pdf
  5. #5
    Join Date
    Mar 2020
    Washington DC
    Posts
    Thanks for the help , it's is very appreciated
    I've got the service and Cylmer manuals
    got it running ,(little rough) waiting for ice to melt and try an idle drop adjustment .
    Stock tachometer doesn't seem to work
    When I took it apart original no adjusting caps on pilots were a 3 1/4, 1 1/2, 2 1/4 and 4 1/2 to stop ?
    Sounds weird right ? I wonder why
    All new pilots are set at 2 5/8 and need to bring idle up .
    Looking at buying Motion pro screwdriver but 2" at turn will it work ?
    It's $30 cheaper than the socket adjuster (1 1/4" high)
    Tight fit
    BTW- has anyone removed the bulky bracket holding carbs together next to pilots ?
Similar Threads
  1. New member- Carb work 1981 cb750 dohc Cafe racer
    By Nbates in forum The DOHC Garage (1984+)
    Last Post: 02-12-2021, 12:38 PM
  2. What is the Stock Jet Size on an 81 CB750?
    By MotersickleBum in forum Carburetors / Fuel
    Last Post: 11-22-2018, 01:49 PM
  3. K6 Carb Slow Jet Question
    By Friartuck in forum Carburetors / Fuel
    Last Post: 05-18-2013, 03:45 PM
  4. Slow jets
    By CB750Todd in forum Carburetors / Fuel
    Last Post: 03-08-2013, 12:09 PM
  5. Are there shorter cables for clubman bars? 80 750K
    By pjmule in forum The DOHC Garage (1979-1983)
    Last Post: 01-28-2013, 10:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
