I don’t remember, maybe 78 kz650. You will also be able to use eye to eye shocks with it.
Yeah, that will work. Be sure to get the kz pivot shaft. You will need to ream the cb750 pivot holes slightly, but not much for the larger kz pivot shaft.
K and F swingarm are same part but the drum brake adds a bolt on point for the stay arm and the disc brake one the same but they are in different places, one on top and the other on bottom. '79 uses plastic bushings, '80 and later use needle bearings.
