Results 1 to 4 of 4
Thread: Whining noise
  1. #1
    CB750 Member Hunter1919's Avatar
    Join Date
    May 2019
    Memphis
    Posts
    10
    Whining noise
    Trying to get a 78k cb750 running again. I had a friend install a new wiring harness (because I have no experience with electrical work). I just installed a new headlight assembly which is metal and not plastic (might make a difference?). I plugged in the headlight and turned the key. It came on but was accompanied by a high pitch buzzing whining noise. The headlight is grounded to the mounting bolts. Is the metal casing making that noise or are the wires messed up?
  2. #2
    CB750 Member KRBJ's Avatar
    Join Date
    Jul 2019
    Fort Bragg
    Posts
    12
    Quote Originally Posted by Hunter1919 View Post
    I don't think the wires would cause this. I would tap around on the bucket and listen for any movement and start taking it back apart and see what is loose it is most likely is metal on metal (where the bucket makes contact with the fork ears) that might need a fiber washer to fix it. If that is what you have to do make sure you maintain your ground.
  3. #3
    CB750 Guru amc49's Avatar
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    2,897
    Look for the audio turn signal buzzer on that one, they used them around that year to let driver know the signals were still working. That one may be acting up, simply unplug it to stop the noise.
  4. #4
    Join Date
    May 2019
    Memphis
    Posts
    10
    Sorry I shouldve closed out this thread. After many attempts I got everything wired right and the noise went away.
    However i am having problems with my speedometer lights and running lights. I was going to start a new thread but I'll just ask yall.
    Wires all have continuity. Running lights only work in park. No speedometer or tachometer lights. All new bulbs. Got a new ignition switch and that didnt fix it. Power to the fuse is 5-6 volts. Is it supposed to only have that much or does it need the full 12?
Similar Threads
  1. Clutch noise
    By The savage in forum The DOHC Garage (1984+)
    Last Post: 12-14-2017, 04:02 PM
  2. Help with engine noise
    By shaunbe in forum Engine / Exhaust
    Last Post: 05-31-2017, 07:26 AM
  3. transmission noise
    By X1R9734 in forum The CB750 Garage
    Last Post: 04-09-2016, 03:22 AM
  4. 76 CB750 Noise
    By Halcyon402 in forum The CB750 Garage
    Last Post: 10-02-2013, 03:26 PM
  5. Engine noise/knock??
    By PharmD750 in forum The CB750 Garage
    Last Post: 09-13-2013, 07:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
