Results 1 to 5 of 5
  1. #1
    CB750 Member diggidan's Avatar
    Join Date
    Mar 2018
    Sweden
    Posts
    18
    Final drive retainer looseness
    My whole front sprocket for the drive is loose.
    And as far as I can see I can't adjust it in any way.
    I just put on the retainer ring and bolt it tightly but it's like the whole retainer is a bit skinny.
    How can I adjust this?
    Maybe I need a new retainer ring?
    I mean, if I put spacers between the retainer ring and the sprocket, I just move the sprocket closer to the engine.
    I'm totally lost.
    Sorry if my English doesn't make sense!
    Here's a video of the problem:
    https://youtu.be/Q1UCL4GGvDU
  2. #2
    Moderator dirtdigger's Avatar
    Join Date
    Feb 2012
    Black Hawk SD
    Posts
    2,805
    Its supposed to be loose, the sprocket is a floating setup on the sohc motor.
  3. #3
    Join Date
    Mar 2018
    Sweden
    Posts
    18
    Quote Originally Posted by dirtdigger View Post
    So it ok for it to wiggle sideways then?
    In this manner: -/ -\ -/ -\
    If you get what i mean!
  4. #4
    Join Date
    Feb 2012
    Black Hawk SD
    Posts
    2,805
    Yes some amount is normal.
  5. #5
    Join Date
    Mar 2018
    Sweden
    Posts
    18
    Allright!
    Seems odd but I thank you for the info!
Similar Threads
  1. Final drive gearing.
    By shaunbe in forum Engine / Exhaust
    Last Post: 01-18-2019, 08:46 AM
  2. The Final Countdown
    By Wez_ in forum Engine / Exhaust
    Last Post: 12-18-2017, 06:39 PM
  3. tight speedo drive
    By cabintommy in forum The DOHC Garage (1979-1983)
    Last Post: 08-12-2017, 02:07 PM
  4. Is this even drive-able?
    By Althezenman in forum The CB750 Garage
    Last Post: 08-19-2016, 09:37 AM
  5. Rear bearing retainer tool
    By RhythmNSteel in forum The CB750 Garage
    Last Post: 12-15-2014, 06:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
