Auxiliary lihhtd
Skelee
161
16
Hamilton, Canada
Finally hooked up the lights. I have wiring harness with fuse and switch. I will wait and test them.
I have those on my BMW. Interesting mounts. Did you make those?
It looks like they are on your fork sliders...
What did you connect them into for power?
I bought them on amazon i bought handle bar swtch but i need help. Switch wires are black(+), brown(-) and blue(equipment), relay wires are blue, black and white?
My guess wss black to black, blue to blue, brown to white. I must be wrong.
That's weird that the black is +.
The Germans (Porsche/VW) did that before though. Where brown is negative. Brown is earth, therefore it was ground.
Your link shows it has red, black and a white for the harness. The link also shows a grey (presuming black), red and a white.
With the switch and relay hooked up, do you get a black (positive) and brown (negative) output? Check with a meter.
The LED lights will only work with positive on positive and negative on negative. They won't work like a light bulb would if you switched polarity.
If you don't know which one is which on the bulb. Check with with a fused line directly to the battery. If it doesn't work one way, swap positive and negative to the LED. Then you will know which is which on the bulb.
I hope that makes sense.
Sorted out thanks! I blew fuse too. So vedict is blue to blue, black to white,brown to black.
Once i test the height of lights and angles i will do a pic.
Thanks all
Good job!
I put a dimmer on mine thinking they were too bright. I haven’t turned them down or off since the first week I was playing with the dimmer. They are always on now.
If you haven’t already, I hope by changing all incandescent bulbs to LED I’m saving my rectifier and stator and battery to last longer.
Good luck.
I have led headlight, rear light and brake light. I cant be bothered with blinkers yet. I keep bike on tender just to be sure
