77 CBk Mechanical Question
ctnighthague
New Haven, CT
I have A 77’ CB750K that has pod filters and I cafed out. It starts perfectly, idles great, and rides fine. My main issue is sometimes while giving it throttle in any gear it hesitates/bogs, but if I let off throttle lightly and then re give it the gas it picks right back up. I’m new to this and new to this type of stuff so I was Hoping someone could tell me where to look/ start. Any help is great and sincerely appreciated.
When it bogs hold the throttle there and try slowly closing the throttle, if it picks up its lean, if it bogs worse it too rich. But if you havent you should go through and check all mechanical and tune up items, check compression, check/adjust valves, clean and adjust points...set timing and dwell, check plug gap, adjust cam chain, check float levels, sync carbs.
