Oil in distributor housing
raene
22
Delta, BC
I pulled the inspection cover to check & set the timing (which was way off) only to find a big puddle of oil in the bottom of the distributor housing. I'm guessing there's a major seal at the back of the housing? Any "gotchas" in removing the distributor I should be aware of? One more part to order...
1982 Honda CB750 Custom. Thanks in advance! :cheers:
There is no problem. The ignition side of the dohc is in oil.
I have oil in the ignition area also and my shop manual didn't mention I would find oil where the CDI is located. How can the engine timing be unaffected when oil is splashing around? Thanks.
The ignition on the dohc is magnetic pickup, oil wont effect it.
