exhaust
Front will fit but back mount may change some. The pipes hang about a 1/2" lower due to thicker cylinder block on 900. If 900C the back has shaft drive and subtrans which will move the back mount. 900 may have middle (collector) mounts the 750 has no holes on pan for.
yea my cb 7 has the single exhaust and it is cracked rotted what not I bought it from an auction and the numbers match frame and engine so with a little love it'll be a go i'll score some original pipes at some point until then ill make some of the adj's on cam chains do the carb kits and sync but I'd prefer to have the factory exh so the tune process is correct thanks for the info
