Wiring designation
Terry Carter
18
Canada
Hello can anyone help with a wiring question. Wires coming from the alternator. The 3 yellow are for the reg/rec but I also have 2 solid blue ones that are the same length and a short blue one with red stripe and short green one with a red stripe. Trying to look online but no luck. Thanks in advance.
What harness are you using?
Blue on my K4 w new 4into4 harness is breaker to coil. Blue w Red is oil press switch to indicator bulb, and Green w Red is clutch switch/starter safety/start switch.
I have a pretty killer interactive diagram I made when I was doing mine. It's too big to upload as a pdf here but I can put it up online if it'll help. Lmk.
Here are some screenshots from it w those colors isolated. This is for a US K4.
Ok thanks. The bike came with an m unit from motogadgit, new reg/req and new starter solenoid but nothing connected. I would really like to see that diagram. 👍
No prob. I'll try to get it uploaded today or tomorrow. Those screenshots show the three circuits you mentioned buy color.
I don't know a lot about the motogadgit setups, but point to point they should be similar w the exception of color.
My Rick's reg/rec had matched wiring.
Starter solenoid had it's own colors but doesn't matter how it's hooked up.
Much appreciated !! Would my email be a way to get it to me. ? If so. Callcarterfirst@gmail.com
