rhackney
Greetings,
Its great to find an active community for such a fantastic machine.
I am currently doing a front wheel rebuild and at the point in the project where it is time to install the new front wheel bearings. I am using the AllBalls kit 25-1307
My current dilemma is this:
Before I purchased a blind hole bearing puller, I made a really enthusiastic effort to drive the old bearing out. In doing so, I deformed the little tabs on the axle collar that is pressed between the two bearings. So deformed in fact that once the bearings came out, I was able to remove the little rings that the tabs are connected to on the axle collar. (See Pic)
Do I really need to have these tabs on the axle collar when reinstalling the wheel bearings?
I don't really see the need for them due to the fact that each replacement bearing is sealed on both sides. I have noticed from parts fiche on later models that these tabs are not part of the axle collar and bearing system.
Please advise!
Please advise!
