VIN plate missing on headstock
Firbb
13
Southam
The VIN plate is missing on my 1972 K2 and I would like to replace it. It is a UK bike and I know the frame and engine numbers and have a full title with it and I am happy with the bike's history and documentation, I just want to put a VIN plate on it.
Can anyone recommend a reputable supplier?
Also should the plate be glued on or rivetted?
Any ideas why it is missing?
These guys are doing reproduction stickers. I have never used them or never been in your situation. Make sure that your headstock has the VIN stamped into it and the numbers that are there matches your owner documents before you do anything. The 2 most common reasons I can think of why yours is missing is 1- someone took it off to repaint the frame and 2- the bike was stolen. They are glued on at the factory like any other sticker.
http://www.bdesigns.ca/Rubber_Samples.htm
That’s really helpful thank you although since I’m in the UK a supplier local to me would be better.
Interestingly the frame has never been painted so maybe the bike or just the sticker was stolen at some point.
As long as the numbers that are stamped into the headstock are there and they match your ownership documents then you have nothing to worry about. The place that makes the stickers I mentioned was just an example. For me, if I had a bike without the sticker I wouldn't bother trying to get a replacement. A sticker that appears fake might just cause more doubt and problems down the road.
UK here also,
Some blank vin plates are remade mostly by one make specialists for restorers . You could contact David Silver if he hasn’t got any he may put you on to someone who has. Then use stamps and put your numbers on . It must then be permanently affixed to the frame.
As far as the legal requirements go the relevant number as shown on the V5c should be displayed on the frame on a metal fixed plate. I made a custom chop using a hardtail frame and most of a Triumph. The original T140 frame was baldy twisted following a collision with something hard. I stamped a aluminium plate with the Triumph frame number and riveted it onto the chops headstock. ( The original frame was then chopped into small chunks to stop it falling into the wrong hands. ) It could cause problems two bikes with the same frame number logged with the DVLA.
The Triumph chop is still being used it has changed hands many times and been MOTd many times, all you need is a fixed plate with the correct numbers easily seen and permanently affixed to the bike although to be honest it would look nicer with a pre printed Honda blank and just stamp your frame number onto it . Good luck try all the classic Japanese machine restorers or even the VJMCC for help.
