Oliver Boy
Hi guys.
I'm starting a carb improvement project; my '81 has never started very well and I'm tired of hanging onto the throttle for 10 minutes every time I start it up.
The bike is now going have to be a daily commmuter -rain and shine- it's got to be more user friendly.
After checking valve clearances, timing and cleaning the carbs, I intend to drill and adjust the idle jet (I'm told it runs to lean on modern fuel) and then balance the carbs.
Am I missing anything ?
Can anyone recommend a good set of vacuum guages?
You use air pressure to do this. That is you make a custom hose that screws into the spark plug hole and connects to an air line. If you don't have a compressor one of those small 12v tire pumps will work. Leave it running because the air will leak past the rings.
