Upcoming project
Nutela
15
Kosovo
A friend who has been working for quite a few years with custom motorcycles gathered up a list of parts to build me an upcoming project on a CB750 Nighthawk, I told him I want to build a unique bike with the most pristine, qualitative, robust and that performs good. He came up with this list of parts, I would appreciate to see your inputs regarding it, if it is missing anything or if there could be any improvements or tips.
There are four Honda Nighthawks close to my location in mint condition:
• 1991, 1992, 1996, 2003
• Mileage: Approximately 17k miles each (1991 model has 26k miles)
• Price: Around 2k euros each (2003 model is 2.5k euros)
Should I wait for an older model, or are these Nighthawks worth considering for a major upgrade and rebuild?
I can spend around 30k-35k euros if needed.
1. Engine Block Components
- Wiseco or JE forged pistons, big bore kit 836cc
- Carrillo Connecting rods
- Falicon Crankshaft
2. Cylinder Head Components
- Kibblewhite valves, valve springs and retainers.
- Web Camshaft
- D.I.D Cam Chain and Tensioner
3. Fuel and Air Components
- Mikuni RS34 Carburetors
- K&N Air Filters
4. Ignition and Electrical Components
- Dyna S Electronic Ignition System
- NGK Iridium IX Spark Plugs
5. Cooling and Lubrication
- Honda OEM or K&N Oil Pump
- Jagg Oil Cooler
6. Gaskets and Seals
- Cometic Full Gasket Set
- OEM or SKF Oil Seals
7. Exhaust System
Headers and Mufflers
Custom fabricated, stainless steel and hand-bent
8. Chassis and Suspension
- Showa/Öhlins USD Fork
- Öhlins Mono shock
9. Braking System
- Front Brembo
- Rear OEM or Vintage Drum brake
10. Seat/Upholstery
- Posh Japan
11. Electronics
- Motogadget m.unit Blue
I think you have 3 threads going on the same subject now. After working on bikes for over 50 years you get to like certain bikes over the others. This is one of those times.
