Torque
Baua
5
Sweden
Hello!
I am trying to find the torque specs for the K2 screws. I need some help here.
Regards
Magnus
Specifics are in the FSM...
But theres gereral torque values for bolts...
Are they screws or bolts....??
Torque recommendations governed by the shank size not the bolt head size...
I have the dohc list thatll b similar...let me know if you want that...
Hello everybody!
In need to torque the fork and the things that are mounted to i. I also need to torque the steering and the things that the steering is mounted on. I think I can use the same torque from later models, better than nothing so please send me that👍. I have learned that screws have shreds and bolts have not maybe a hole for a sprint or a few threads so the bolt wouldnt leave the hole, am I right here🤔
Many thanks for your answers
Regards
From Sweden
Im sure another sohc owner/moderator will supply the sohc data....
But specs for DOHC versions attached....see the "standard torque values" at the page bottom.
I did find some SOHC shop manual tables-now attached also
  • torque DOHC.pdf
  • torque_SOHC.pdf
