conradcb750philly
Hello forum,
I need some advice from the experienced folks on a blue smoke problem.
I purchased a 1978 CB750F Super Sport last week. It has 29k on the clock.
The previous owner had it for four years, and it seemed to run well when I gave it a close look before purchase, but I think I have discovered a (somewhat?) (serious?) problem.
Here are the symptoms:
- blue-ish smoke from the tailpipe that is clearly visible in bright daylight
- smoke is subtle when engine is cold, and gets worse as the engine warms up
- smoke gets thick under load/acceleration
- the front of the valve cover has some seeping oil, at the edge under the round caps where you adjust the valves. It is not clear if this is related, or if this is just a coincidence. The oil does not seem to be from the round caps themselves.
Based on my internet research, I believe I may have either of these problems:
- a failed valve cover gasket
- some bad piston rings/oil control rings
A few specific questions:
1) How serious is a blue smoke symptom on an air cooled engine? Is it a terrible idea to ride the bike a few miles in this condition? Am I doing damage to the engine? Some internet forums suggest that this is risky for the engine, but that seems to apply to water-cooled engines, not air-cooled engines.
2) Is oil seeping around the front of valve cover (near the spark plug holes) likely related to the blue smoke, or just a coincidence?
3) Am I correct that for a bike that is over 35 years old, with old 30k miles, an old gasket is much more suspect than bad rings on the pistons? Or am I making some wild leaps of logic here?
4) Given the age and relatively low mileage, should I first try to replace the valve cover gasket? Is seems that would be much easier than dealing with pistons.
5) Is a valve cover gasket replacement a pretty reasonable DIY project for somewhat who is comfortable, say, adjusting valves?
In case anyone can speak to their experience, I would greatly appreciate it! I'm somewhat mechanical, but this feels like I'm getting into more complicated work, and I wanted the wisdom of those who have gone before me.
Thanks kindly,
Conrad
West Philadelphia PA
1978 CB750K Super Sport with 30k
Thanks kindly,
Conrad
