Tail light 73' CB750
The taillight on ebay is grounded through the mounting screws and honda uses actual ground wires. You can use the light just hook up the two wires, one for brake light and one for the tail light. Leave the ground wire unhooked. Be sure the screws have a good ground in the fender. Or even better yet take the ground wire and attach it to the tail light assembly so you will be sure it is grounded.
Nope makes no difference. You can try just bolting the light on and attaching the two wires first then see if it works. If it doesn't then you can add the dedicated ground.
