Tachometer Ratio
amzonprncess83
7
Huntington Beach
Alright, I've looked and can't find it anywhere. I've found the speedometer ratio, but can anyone tell me what the tachometer ratio is for an '82 CB750F2??? Or at least point me in the right direction where I CAN find the information! Thanks
FWIW...If no published answer....One way to verify is unscrew cable end from tach.....rotate crank 10 times while observing cable end rotation(number of cable end rotations)get your ratio....
Good to know! Thank you! Part of my problem with that is though I do not currently have a tach on my bike. The previous owner removed stock gauges and only installed a speedo.
Large cc Hondas of that time generally 4:1....
You could check aftermarket tach compatibility in a site like Randakks if no definitive answer from the forum.....
Sohc are 4:1...as are most bikes of the era.. 750 and above.
Im away from home so cant test my Dohc K using method described...
Good info! Thank you!
