stuck screws on 92 carburetor brackets
nogalarry
California
Mistakenly first posted in SOHC section...any tricks to getting these screws to budge? Tried pb blaster, no luck. Need to remove the carbs to replace o rings due to leaking fuel.
Thanks
If they are the ones I’m thinking of they will be JIS - Japanese Industry Standard. If you haven’t got a JIS screwdriver already, I recommend you get one and use it in conjunction with the penetrating oil, and patience. I found the JIS made a difference. When they engage in the screwhead to undo they sometimes make a “click”. On my ‘96 carbs I bought one of those JIS screwdriver bits that fit into a holder which then fits a 5/16” t-handle....plenty of solid but careful leverage.
