Stuck caliper bolt
evanphi
10
Canada
1975 CB750...
I need to clean my caliper piston and cavity, so I need to get my caliper off. My front caliper bolt won't come off. I've tried pounding it with a manual impact wrench, as well as heating it up first. All this after soaking it in PB Blaster for a few nights in a row. This is futile anyway because of the location of the threads. They're impossible to get to. It won't budge. The rear one came loose with a couple taps of the impact wrench, no problem.
Any tips? Should I try tighten-loosen-tighten-loosen...etc with the impact wrench to break up the threads?
I'd like to avoid drilling the head off this bolt... :-\
Yay! Breaker bar worked. I also used a new 8mm hex dedicated socket instead of the bunch of reducers/adapters.
Product at Harbor Freight for those in the US of A
