gotorx7
Hi.. recently bought a CB750K2 and going through it fixing up some bodgeyness previously inflicted..
Pulled the carbs and cleaned jets, bowls etc (Bowls were clean, 2 idle jets were partially blocked.)
While balancing the carbs I noticed the throttle was sticking open, and needed a push to close.
So now I've replaced the throttle cables as they were showing signs of wear at the carby end, and it is a little better, but still sticking.
Tonight I loosened off the caps on top of the slides, and throttle doesn't stick. Tighten them up (even loosely) and I'm sticking again..
Anyone come across this before? It has me a bit baffled...
Cheers, Dave
Cheers, Dave
