Shifting without clutch
Jarrett_Honda
29
Spokane, Wa
My clutch(cb750k5) is basically useless. I'm able to shift up and down without using it. I understand that shifting up isn't a big deal, but downshifting is.
I can also go through the gears when the bike is off.
I adjusted the clutch just like the manual says. I also have a new clutch cable. To fix this would I have to remove the whole clutch assembly to replace everything inside?
-Jarrett
New or used clutch? brand? Clutch basket have notches worn in it? Have you done any looking inside at the actual clutch yet?
I believe its the original, I'm not syre what tge prevonwer had done to it. I haven't looked inside yet. I wanted to know what to suspect to make sure I order everything at once. Normally we just change the friction plates correct?
I use complete clutch kits from Cycle X, friction and steels. You could have warped steels causing it to drag too, need to take it apart and start inspecting.
