Got a set of 4 into 4 Sankei pipes. These came from someone else's project bike, and I'm not 100 percent sure what bike they fit because the project bike was a bit of a Frankenstein that had been welded into a hardtail. The headers look like they'd fit a 1979-1982 DOHC CB750 (they look basically the same shape as the headers on my 1980 750K) but I think the engine that came with the project may be from a 1983 Nighthawk. The frame it came with is a 1981 model year DOHC bike.
They're painted black with some kind of paint that's just jumping off of them when touched so it should probably be stripped off. There are bits of external rust here and there but they're mostly in good shape, except for one sketchy spot that's on the pipe for cylinder 4. See the pictures. I'm not sure if that is it rusting from the inside out, a hole in just the outer pipe, or something else. If I can find the four exhaust flanges that fit them, those will come with as well, but I only know where 1 is at the moment.
Hoping for $150 for the pair (or best offer), located in Franklin, Tennessee. Local pickup is of course easiest and I'm willing to drive about an hour to meet you. Will ship anywhere else at your cost.
