Rubber washers on the top the Engine
BIKERDAD
83
21
Cardiff uk
Hi everyone hope everyone's OK
OK I got a PReg 1996 CB 750fn2 so iv cleaned up the top cover undone the 8 bolts cleaned the bolts up
Now there 8 metal washers with 8 rubber washers now I can't find the type I need all the ones I've found so far the rubber has like a nipped going in to the head .the ones I need are flat .
There is one seller wanting £9 for one washer 1 washer yep I did ask if it was a set nope 1 single washer...
I do have a small tap washers that fit over the bolt and wondering if I could use them underneath the big honda washer .
Not sure if a tap washer would do as there £3 set of 4 . . Thanks ŵ
Found this on ebay this is what im after try pop a photo up but this is one for sale its £7 not £9 ,.................
Athena Seal Valve Cover Bolts Rubber Mounting Fits Honda CB 750 1991-2024
The metal washer is on top this and you tighten it down it pushes the metal washer down on to the rubber washer . The rubber washer i have are hard but im guessing the new ones are softer.
These are the ones i keep finding. See how there not flat as the nippel sticks down and there's no room in the head for the bit sticking down .
Here's the one I keep finding finding Can't use
Hi thank you i have mesaged them .
Are they anything special about them.would any type washer fit .. are they rubber or silicon ??
They look and fit just like the ones I took off I replaced the valve cover gasket because it was leaking so I changed them as well so far no leaks. They look like your picture. But mine is a 92 so I would check for fit. P.S. took a few weeks to get but the price was right. Good luck.
Hi i got the vwry same wee leaks so changed it just having probs finding the same washers few weeks i can do lol cheers for your help
