Replacing warning light bulbs
muzzy
13
New Zealand
Hi What is the best way to remove these bulbs to check as my oil warning bulb isn't operating, I have power at the pressure unit but bulb doesn't light up.
Do I need to remove the gauges? I removed the clamp holding the panel but still couldn't get access
Thanks in advance for any help. I don't want to start until I have sorted this issues.
The bulbs are in the top handlebar clamp, when removed you have easy access to the bulbs. Should be right there ??? maybe send a picture of what you took off🤷‍♂️
Thanks I think the problem was the cable was pinched on the frame and wasn't allowing enough slack to allow easy access to bulbs
I have eliminated the bulb being faulty and now will have to remove and test the pressure switch
Thanks for your reply
