I bought a 1977 CB750K a month ago, had the same bike 45 years ago so I'm stoked to have it. I've been going through it as rubber anything hardens and cracks. I also did a valve clearance test .002 intake, .003 exhaust, and a compression test 92-120 PSI across the 4. I have 2 questions and I've read everything I could on this forum in regards to low compression.
1.It has been said that the stock shim thickness from Honda is too tight? some people were talking .005-.007?
2. Compression being low and so uneven across the 4 I'm thinking that I need to pull the motor and do at least the top end? Where is a reputable place to purchase what is needed for a top end rebuild? A kit or something?
3. I am not aware of any other checks I can do other than clearance and compression, so any education is extremely welcomed.
