Pilot screw snapped
Screechers41
Minnesota
Hello, I recently purchased a 1981 Cb750 custom and it has the issue with the idle hanging when coming to a stop. Before I tore into it to check valve adjustments I wanted to verify pilot settings. I noticed 3 screws were accounted for and the 4th appears to have been snapped off. Would a small easy out be my best bet? Open to suggestions...
That adjustment screw is brass and pretty pliable (compared to other metals), so you might be able to get a flat tip in there to turn it out. Unless of course, it is seized for some reason. Look up a pic of that screw so you can see what sort of size extractor you'll need. It likely needs to be pretty small.
Go and buy yourself a small "Left Hand" drill bit. Maybe 1/8th or so. Make a small punch mark in the center then use a drill going counter clockwise. The counter clockwise motion of the bit as it's grabbing material will probably grab and spin the screw out. Done it many times. I have a set of left handed bits just for this purpose. You can probably get a cheap set at Harbor Freight.
Thanks! I have a left handed drill set and didn't think to try that. I wonder if I can get in there without pulling the carbs...
