I'm new to SOHC CB750's, I noticed that when my bike sat for a while a lot of oil drained from the tank back into the case, likely overfilling the case which from what I read is called wet sumping on these models. In my cafe rebuild I'm going with a custom oil tank and 8AN lines. In order to prevent wet sumping should I install an 8AN shut off valuve in both the feed and return lines that I can close when the bike is being stored for long term? Yes, I know I would need to ensure I never start the bike with these in the closed position. If I don't go that route, is it bad to start the engine with that extra oi in the case or is there a simple way to purge the excess oil from in the case before starting without having to drain the case and refill? Does the wet sumping happen from both the feed and return line or just on the feed line?
