Seems to be coming from the split between the case and crankcase cover. Drain oil and inspect the paper gasket, its cheap so order it before you take things apart.
The two big bolts on the bottom keeps the case halves together, the two small ones on the side keeps the crankcase cover in place. The two small ones seems to be the origin of the leak.
