no power
bprassel
round lake beach, il.
I have a 76 cb 750 I went to ride bike this past weekend and turned key and no power I had battery tested it is fine this has happened before and I would smack the wiring under side cover is it something their or could the ignition failed
If wiggling the wires behind the side cover (especially around the starter solenoid) doesn't get you power I'd also fiddle with the fuse in case there's not good contact there. Stab in the dark, but if smacking has worked before, is certainly worth a try. Dirty connections are relatively common... cleaning and tightening may be in order.
