No power on my CB750
fatoldo
7
long island NY
1978 cb750 four k carbs.
hello all, I have rebuilt my carbs on my 78 cb750. the bike is back together and it runs. At first it had no power. then I adjusted the 4 carb screws till it seemed to have power. Rode it up and down the block a few times and all seemed fine. today, 2 months later i started the bike up. It started very easy. but after warming it up it didnt have enough power to get me up my drive way. Also one other thing. Before I started it i turned on the fuel valve. after a minute of it just sitting there gas started coming out of a hose. not sure what hose but it wasnt one of the bowl hoses.
History of the bike. I just got it last summer. it was running but again seemed to have no power which is why i took off the carbs. The bike sat since 2005 outside , uncovered till i bought it this past summer. its got 8k miles on it. it looks like hell but its all there and just needs TLC to make it nice again. I have rebuilt a carb or two on cars but never a bike. this was my first. I took them down to nothing and replaced all parts that came in the kits. As it is now, the set screws are turned out about 4 to 5 turns. It seemed to run the best this way 2 months ago. I thought it was a bit much (the4 or 5 turns out) but it seemed to like it. The original way i found the bike it was 3 turns out on the screws.
any ideas?
Morning fatoldo,It seems like your fuel level is to low in the carbs,the carbs are set upside down so the float height is to high that's why it's running with the set screws so far out,,which means its ONLY running on the mixture screw settings,,did you blow all the jets clean,don't use steel wire to clean them,I use a strand of copper wire from the inside of a piece of flex elec cord to break up the more stubborn gunk.Here is a good pictorial on setting the float heights,hope it helps : http://www.hondachopper.com/garage/carb_info/float_levels/float_levels.html There is a lot of useful info on that site,good luck,I wish we could pick up those old Honda's here in South Africa as easily as over there.
Hope you come right
Anthony
