Hey guys,
Looking for some help with a neutral light and oil pressure light issue on my 1982 CB750K.
The bike came to me with an aftermarket mini speedometer/tach setup, and since the day I bought it neither the neutral light nor the oil pressure light has ever worked. Everything else on the gauge works fine.
Over the years I've tried quite a few things to fix it:
Following the wiring diagram, I connected the neutral light positive to the brown/white gauge illumination wire and connected the neutral light ground side to what I believe is the light green/red neutral switch wire from the Honda harness. The neutral light then comes on, but it stays on all the time, even with the engine running and the bike shifted into gear.
At this point I'm trying to figure out whether:
idk what i am doing wrong but there is obviously some thing out of wack.
Has anyone run into this on an 81-82 CB750K with aftermarket gauges? If anyone has a photo of how they wired their neutral and oil pressure indicators or can point out what I'm missing, I'd really appreciate it. ( will include photo of the gauges i have tried to wire but with no success for the neutral or oil light)
cheers,
- Replaced the complete wiring harness.
- Replaced the neutral switch.
- Replaced the oil pressure switch.
- Checked and reworked wiring connections several times.
- Verified that the indicator LEDs in the aftermarket gauge actually work by powering them directly.
- Using the OEM gauge cluster connector for most of the wiring.
- I'm somehow on the wrong wire in the OEM connector.
- The neutral circuit is grounded all the time somewhere in the harness.
- I'm misunderstanding how these aftermarket gauge indicators are supposed to be wired.
cheers,
