peterdancy
I have 1974 CB750 Honda custom chopper, I picked up second hand. There was no wiring harness, it has bare minimum wiring. the rectifier, the voltage regulator and the starter solenoid is all located in a hand made control box. Its all ran thru toggle switch and a push button start with no key ignition. When I obtained the bike, the box was a mess. I ran basic wiring and I think I made a mistake by running a constant power lead to a switch and the ignition coils to the same switch. Need to know where to run the positive lines from my ignition coils?????? any and all help would be greatly appreciated...im at a total loss
this is the box that the voltage regulator rectifier and starter solenoid are mounted in
